Error While installing edge-impulse-cli on windows
Hi! My system is Windows10 2004
when I’m installing the [Edge Impulse CLI], I got problems as the screenshots show
the node.js and npm has already installed
I tried to uninstall it and try again, but the same error occurred
Also, I’m using Administrator mode to open cmd.exe
I’ll be very grateful if I can get help
error log:2021-03-13T09_30_29_140Z-debug.log
I’ve solved the problem by setting proxy…it’s because my network cant connect
I am getting a similar error on my Windows 10 machine. Would you mind sharing more detail of how you set the proxy?
