I have a problem to install Edge Impulse CLI tools, the prompt shows me an error saying that request for node.js is not longer available.
Also I cannot run the Impulse daemon
npm install -g --force edge-impulse-cli
npm WARN using --force I sure hope you know what you are doing.
C:\Users\52333\AppData\Roaming\npm\edge-impulse-blocks -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-run-impulse -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\run-impulse.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-daemon -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\daemon.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-data-forwarder -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\data-forwarder.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-uploader -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\uploader.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-linux-runner -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\linux\runner.js
C:\Users\52333\AppData\Roaming\npm\eta-flash-tool -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\eta-flash-tool\flashtool.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-framebuffer2jpg -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\framebuffer-to-jpg.js
C:\Users\52333\AppData\Roaming\npm\edge-impulse-linux -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\linux\linux.js
C:\Users\52333\AppData\Roaming\npm\himax-flash-tool -> C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\himax-flash-tool\flashtool.js
edge-impulse-cli@1.12.5
updated 1 package in 26.393
prebuild-install WARN install No prebuilt binaries found (target=14.16.0 runtime=node arch=x64 libc= platform=win32)
C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings>if not defined npm_config_node_gyp (node “C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\…\node_modules\node-gyp\bin\node-gyp.js” rebuild ) else (node “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” rebuild )
gyp ERR! find VS
gyp ERR! find VS msvs_version was set from command line or npm config
gyp ERR! find VS - looking for Visual Studio version 2017
gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
gyp ERR! find VS checking VS2019 (16.8.31019.35) found at:
gyp ERR! find VS “C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools”
gyp ERR! find VS - found “Visual Studio C++ core features”
gyp ERR! find VS - found VC++ toolset: v142
gyp ERR! find VS - found Windows SDK: 10.0.18362.0
gyp ERR! find VS - msvs_version does not match this version
gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
gyp ERR! find VS looking for Visual Studio 2015
gyp ERR! find VS - not found
gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
gyp ERR! find VS
gyp ERR! find VS valid versions for msvs_version:
gyp ERR! find VS - “2019”
gyp ERR! find VS - “C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools”
gyp ERR! find VS
gyp ERR! find VS **************************************************************
gyp ERR! find VS You need to install the latest version of Visual Studio
gyp ERR! find VS including the “Desktop development with C++” workload.
gyp ERR! find VS For more information consult the documentation at:
gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
gyp ERR! find VS
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Visual Studio installation to use
gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
gyp ERR! stack at ChildProcess.exithandler (child_process.js:315:5)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
gyp ERR! cwd C:\Users\52333\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! C:\Users\52333\AppData\Roaming\npm-cache_logs\2021-03-04T02_09_06_637Z-debug.log
I opened an application in my computer with the name “Install Additional Tools for Node.js”, I think that this was not clear for me the first time that I try to install all the tools.
After I open this program, a black window similar to a prompt window appear, this window asked me to press any key two times. I did it and a new blue window appear and it started to install several things, this take several minutes but finally finished it.
I guess that the next step was install the command install -g edge-impulse-cli, but I do not why after I run this command nothing else happens.
I hope you can help me again. In March you help me to install all the tools on my computer and until now is working properly, but now I want to install everything on a different computer and I have similar problems. Of course, I tried all the advice that you told me before, but it didn’t work.
