Help with my project object detection problem is: AllocateTensors() failedERR: Failed to run classifier (-3)
[when i have upload the code using the object detection inferencing that edge impulse have give there’s an error about multi_heap_free multi_heap_poisoning so the solution that i have done is that i change my inference engine and when i have done that now i can upload thecode and again but the new error is all about "
AllocateTensors() failedERR: Failed to run classifier (-3)"]
[1103782]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
[i have expected to have my esp32s3 eye identify 3 different objects in the serial monitor]
[it have given me this error "
  • [ ] Always
