The compiler is complaining about missing initializer clauses in several places within the code related to convolutional layers.
NA
I used edge impulse to create a model for image classification for my esp32-s cam connected with mb board. My camera works perfectly, but as soon as I include the header file from edge impulse there’s this following error:
Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp: In function ‘TfLiteStatus tflite::{anonymous}::Prepare(TfLiteContext*, TfLiteNode*)’:
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1789:67: error: either all initializer clauses should be designated or none of them should be
1789 | .channels = input->dims->data[3], 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1793:68: error: either all initializer clauses should be designated or none of them should be
1793 | .channels = output->dims->data[3], 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1795:80: error: either all initializer clauses should be designated or none of them should be
1795 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp: In function ‘void tflite::{anonymous}::EvalQuantizedPerChannel(TfLiteContext*, TfLiteNode*, const TfLiteConvParams&, const NodeData&, const TfLiteEvalTensor*, const TfLiteEvalTensor*, const TfLiteEvalTensor*, TfLiteEvalTensor*)’:
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1883:58: error: either all initializer clauses should be designated or none of them should be
1883 | .channels = input_depth, 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1887:59: error: either all initializer clauses should be designated or none of them should be
1887 | .channels = output_depth, 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/conv.cpp:1889:80: error: either all initializer clauses should be designated or none of them should be
1889 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp: In function ‘void tflite::{anonymous}::EvalQuantizedPerChannel(TfLiteContext*, TfLiteNode*, const TfLiteDepthwiseConvParams&, const NodeData&, const TfLiteEvalTensor*, const TfLiteEvalTensor*, const TfLiteEvalTensor*, TfLiteEvalTensor*)’:
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1727:58: error: either all initializer clauses should be designated or none of them should be
1727 | .channels = input_depth, 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1731:59: error: either all initializer clauses should be designated or none of them should be
1731 | .channels = output_depth, 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1733:80: error: either all initializer clauses should be designated or none of them should be
1733 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp: In function ‘TfLiteStatus tflite::{anonymous}::Prepare(TfLiteContext*, TfLiteNode*)’:
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1836:67: error: either all initializer clauses should be designated or none of them should be
1836 | .channels = input->dims->data[3], 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1840:68: error: either all initializer clauses should be designated or none of them should be
1840 | .channels = output->dims->data[3], 1
/Users/yam/Documents/Arduino/libraries/Smart-Waste-Segregation_inferencing/src/edge-impulse-sdk/tensorflow/lite/micro/kernels/depthwise_conv.cpp:1842:80: error: either all initializer clauses should be designated or none of them should be
1842 | data_dims_t filter_dims = {.width = filter_width, .height = filter_height, 0, 0};
exit status 1
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
