Edge Impulse with pan and tilt sevos
Hi I want to make a pan tilt camera using esp32 camera (ai thinker) and a FTDI. I want the servos to move/track the object according the position (x,y)
I took the existing edge impulse code and I added( in order to find the center point )a line that calculates the center using the height and width of bounding_boxes
But the servos the don’t move accordingly they move a bit off
        if (bb.value == 0) {
           continue;
        centerX=bb.x+(bb.width/2);
        centerY=bb.y+(bb.height/2);
	    servoX.write(centerX);
		servoY.write(centerY);
        ei_printf("    %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
The output is :
Predictions (DSP: 2 ms., Classification: 131 ms., Anomaly: 0 ms.):
No objects found
No objects found
Predictions (DSP: 2 ms., Classification: 132 ms., Anomaly: 0 ms.):
No objects found
No objects found
No objects found
Son Goku (0.902344) [ x: 16, y: 16, width: 8, height: 16 ]
Son Goku (0.621094) [ x: 16, y: 16, width: 16, height: 8 ]
Son Goku (0.855469) [ x: 24, y: 16, width: 8, height: 16 ]
Son Goku (0.687500) [ x: 24, y: 16, width: 8, height: 16 ]
Son Goku (0.773438) [ x: 8, y: 8, width: 16, height: 16 ]
Son Goku (0.828125) [ x: 8, y: 8, width: 16, height: 16 ]
Son Goku (0.835938) [ x: 8, y: 8, width: 16, height: 16 ]
Son Goku (0.882812) [ x: 8, y: 16, width: 16, height: 8 ]
Son Goku (0.835938) [ x: 16, y: 16, width: 8, height: 8 ]
Hi @GreatoR,
Bounding box information (x, y, width, height) are given in pixels. So, when you calculate center coordinates (centerX and centerY), those are pixels (from 0 to whatever the width/height of your image is). Assuming you are using the Arduino servo library, the Servo.write() method expects an angle in degrees (0 to 180). You need to translate center coordinates in pixels to an angle to pass to your servos.
Thanks for the response !
I am new into this!
I modify the code and look like this, still not working ;/
int servo_min_angle = 0;
int servo_max_angle = 180;
int image_width = 48;
int image_height = 48;
void loop()
        continue;
    int servoX_angle = map(bb.x, 0, image_width, servo_min_angle, servo_max_angle);
    int servoY_angle = map(bb.y, 0, image_height, servo_min_angle, servo_max_angle);
    servoX.write(servoX_angle);
    servoY.write(servoY_angle);
Hi @GreatoR,
What behavior are you seeing from the servo and what are you expecting it to do?
Also, keep in mind if there is more than one bounding box, you will give conflicting instructions to your servos, as you attempt to move them for every bounding box (as given by the for loop).
Tilt servo is going downwards I check the code if I put wrong the pan movement into tilt
I provide you with a video and the code!
In the link the are 2 videos
 * SOFTWARE.
#include "ESP32_inferencing.h"
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include <ESP32Servo.h>
#include "esp_camera.h"
#define LED1 4
#define SERVO_PIN_1 14 // GPIO14
#define SERVO_PIN_2 13 // GPIO13
Servo servoPan;
Servo servoTilt;
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
int centerX = 0;
int centerY = 0;
int servo_min_angle = 0;   // Ελάχιστη γωνία του servo
int servo_max_angle = 180; // Μέγιστη γωνία του servo
int image_width = 48;      // Πλάτος της εικόνας
int image_height = 48;     // Ύψος της εικόνας
void setup()
	servoTilt.attach(SERVO_PIN_1);
	servoPan.attach(SERVO_PIN_2);
	pinMode(LED1,OUTPUT);
    Serial.begin(115200);
    // move all servos to position 0
	servoPan.write(centerX);
	servoTilt.write(centerY);
    while (!Serial);
    else {
    ei_sleep(2000);
* @param[in]  debug  Get debug info if true
void loop()
        return;
    if(snapshot_buf == nullptr) {
        return;
    ei::signal_t signal;
        free(snapshot_buf);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
            //digitalWrite(LED1,LOW);
            continue;
        int servoPan_angle = map(bb.x, 0, image_width, servo_min_angle, servo_max_angle);
        int servoTilt_angle = map(bb.y, 0, image_height, servo_min_angle, servo_max_angle);
        servoPan.write(servoPan_angle);
        servoTilt.write(servoTilt_angle);
        //try and error ..testing..
        //centerX=bb.x+(bb.width/2);
       // centerY=bb.y+(bb.height/2);
        //printf("KEDRO" , centerX,centerY);
		    //digitalWrite(LED1,HIGH);
		    //servoX.write(centerX);
		    //servoY.write(centerY);
    if (!bb_found) {
        ei_printf("    No objects found\n");
#else
        ei_printf("    %s: %.5f\n", result.classification[ix].label,
#endif
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    if (err != ESP_OK) {
      return false;
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
    bool do_resize = false;
    if (!is_initialised) {
        return false;
    if (!fb) {
        return false;
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
        do_resize = true;
    if (do_resize) {
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        out_buf,
        img_width,
        img_height);
    return true;
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#endif
The link! Sorry for the mess in the wiring
https://imgur.com/a/azvUZoC
with only a few snippeds of the code it’s hard to help… I guess:
The camera don’t know where it is atm, so it don’t know where to move.
Hi @GreatoR,
My guess is that you’re still moving the servo far more than necessary. You’re trying to map a pixel (x, y) location to the full range of servo motion, e.g. 0 to 180 degrees. So, if your Goku is at the top of the frame (y=0), the servo will try to move all the way to 0 deg. In all likelihood, that will move your camera too far and Goku will be out of the frame.
I recommend taking an iterative approach. If the center of the Goku bounding box (x, y) is above the center of the frame (image_width / 2, image_height / 2), then just move the camera up a little. Same thing for if Goku is below the middle point. You should also have a “dead zone” where the camera doesn’t move at all (start with something like 10 pixels in either direction):
if (y < (image_width / 2 - 10)) {
  servoTilt_angle -= 5;
else if (y > (image_width / 2 + 10)) {
 servoTilt_angle += 5;
Repeat for the x direction.
Hi GratoR, I’m also facing the same issue. Did you find the solution for the problem? Please share the code.
