Can't connect to edge impulse while running classify
Hi team, can you help me with this? I’m totally desprate :((
How to run edge-impulse-linux while Legacy Camera is enabled? i enable it on raspi-config.
I need to run my classify file (called billing.py).
When i ENABLE Legacy camera, it can run a ‘python billing.py modelfile.eim’ command. But can’t connect to edge impulse, it said “Cannot find any webcams”.
When I DISABLE Legacy camera, it cannot run a ‘python billing.py modelfile.eim’ command, it said “cannot find any webcams”. But can connect to edge impulse, the camera also detected.
I use OV5647 Wide-angle 5MP camera module with ribbon port attach, using raspberry pi 3 and Raspi OS 64bit Full bullseye.
Please… help me team :frowning:
Project ID 298204
For autobilling project.
Hi @Exynosy,
Please see if any of the following threads help with your issue:
