I wanna run my model locally on my Raspberry Pi 3B and a Raspberry Pi Camera Module V2. When I run edge-impulse-linux or edge-impulse-linux-runner the camera is detected and it works perfectly fine. However, when I try to run the classify.py example it returns this:
MODEL: /home/pi/linux-sdk-python/examples/image/models/FOMO-int8.eim
Loaded runner for "Benjamin / Real-Time Object Tracking for Autonomous UAVs"
Looking for a camera in port 0:
Looking for a camera in port 1:
[ WARN:0] global /tmp/pip-wheel-a8gfdc_n/opencv-python_13563f08137a4b20bc4dfee05bcbf854/opencv/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video1): can't open camera by index
Looking for a camera in port 2:
[ WARN:0] global /tmp/pip-wheel-a8gfdc_n/opencv-python_13563f08137a4b20bc4dfee05bcbf854/opencv/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video2): can't open camera by index
Looking for a camera in port 3:
[ WARN:0] global /tmp/pip-wheel-a8gfdc_n/opencv-python_13563f08137a4b20bc4dfee05bcbf854/opencv/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video3): can't open camera by index
Looking for a camera in port 4:
[ WARN:0] global /tmp/pip-wheel-a8gfdc_n/opencv-python_13563f08137a4b20bc4dfee05bcbf854/opencv/modules/videoio/src/cap_v4l.cpp (893) open VIDEOIO(V4L2:/dev/video4): can't open camera by index
File "/home/pi/linux-sdk-python/examples/image/classify.py", line 129, in <module>
main(sys.argv[1:])
File "/home/pi/linux-sdk-python/examples/image/classify.py", line 81, in main
raise Exception('Cannot find any webcams')
Exception: Cannot find any webcams
The camera should be in port 0.
v4l2-ctl --list-devices:
unicam (platform:3f801000.csi):
/dev/video0
/dev/video1
/dev/media3
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
/dev/video18
/dev/video31
/dev/media2
bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/media0
/dev/media1
v4l2-ctl --device=/dev/video0 --all:
Driver Info:
Driver name : unicam
Card type : unicam
Bus info : platform:3f801000.csi
Driver version : 5.15.32
Capabilities : 0xa5a00001
Video Capture
Metadata Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x25200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : unicam
Serial :
Media version : 5.15.32
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000005 : 0: Sink
Link 0x02000008: from remote pad 0x1000002 of entity 'imx219 10-0010': Data, Enabled, Immutable
Priority: 2
Video input : 0 (unicam-image: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'BGR3' (24-bit BGR 8-8-8)
Field : None
Bytes per Line : 1920
Size Image : 921600
Colorspace : sRGB
Transfer Function : sRGB
YCbCr/HSV Encoding: ITU-R 601
Quantization : Full Range
Flags :
Any ideas?
