Please try to fill as much detail as possible, this information will inform our tech team, and give the best time for resolution. Thanks!
[Provide the project ID]
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
