Using Edge Impulse with Raspberry Pi 5 and a Third Party Camera
I am attempting to deploy a computer vision algorithm trained in Edge Impulse to a Raspberry Pi 5 using a third party camera, but the camera is not detected when I try to initialize it with edge-impulse-linux
[Provide the project ID]
Deploying a computer vision algorithm to a Raspberry Pi 5 while using a third party camera.
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
Expected Results:
Actual Results:
  • [ ] Always
Hi @seanhart24,
Thank you for post. Can you provide more information on how to reproduce and error logs?
Which camera are you using? is it a webcam or a CSI camera? Does it work without another tool? like libcamera-hello?
What is the output of
  • edge-impulse-linux --verbose
  • gst-device-monitor-1.0
// Raul James
