Uno Q Keywords Spotting documentation
It seems the Arduino Keyword Spotting brick can only spot one word. If not, where can I find a comprehensive documentation to be able to exploit the data?
I try to deploy my keyword spotting on Arduino Uno Q using the “keyword Spotting” brick. My model contains two words “jour” (day) and “nuit” (night) that I want to use to switch on or off a light. The eim app itself runs pretty well when I try it to my mobile but not at all when I try to deploy it on the Uno Q. In fact, I can’t figure out how to retrieve the prediction results for both word and decide which action to take. For instance, pass the result to the bridge for the STM32 to drive the light
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
Hello @dbodart first of all welcome to the Edge Impulse community!
If you have your own model, did you try to clone the Keyword spotting application from the Arduino App Lab and link to your model?
My recommendation is to clone the application and then move your model here
/home/arduino/.arduino-bricks/ei-models/
Then modify the app.yaml file adding in the keyword spotting brick this variable:
variables: {
      EI_KEYWORD_SPOTTING_MODEL: /home/arduino/.arduino-bricks/ei-models/<name of your model>.eim
Check this tutorial Run Arduino App Lab - Edge Impulse Documentation
You also can check this video https://youtu.be/i_Iq3TTqpgU?t=273
Let us know if this works for you!
