Unable to upload images
[44/44] Failed to upload 1762647697784.jpg: An item with this hash already exists (ids: 2364966656, 2364966676, 2364966666)
Done. Files uploaded successful: 0. Files that failed to upload: 44.
Job completed. No files were uploaded successfully.
I have a new account and am unable to upload any images.
[Provide the project ID]
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
Expected Results:
Actual Results:
  • [ ] Always
Hi @LSP_Dataworks - welcome to the forum; thanks for posting!
Typically when you receive the error message An item with this hash already exists it means that the exact same file already exists in the dataset for your project.
Are you trying to upload the same file multiple times to have multiple instances of it in your dataset?
