Unable to process .onnx model using studio
I have a .onnx model I’m trying to convert to FOMO.
I’ve uploaded the .onnx saved model, but get an error when trying to generate a FOMO model.
  1. Upload model
  2. Select model input as “Image (RGB)”
  3. Try various options for “How is your input scaled”
  4. Model output is “Object detection”
  5. Selecting FOMO as the output layer
    Causes the error: Expected output shape to have 3 dimensions for FOMO
The BYOM documentation just says upload your model in one various formats, of which .onnx is one.
Is there something I’m missing?
  • [ x ] Always
Hi @edgeimpuls_nospam
I’m not sure if you can convert a model from one format to FOMO, there are specific constraints on FOMO and its not a typical object detection model.
It wont work in a way that can be converted from YOLO for example.
Can you try converting to another object detection model?
Hi @edgeimpuls_nospam - building on top of @Eoin’s response.
BYOM is not meant for converting one type of model architecture to another. The idea behind the the “Output layer” parameter when the model output is set to object detection is to select the value that corresponds to the model architecture that you uploaded.
For example,
  • If you uploaded a FOMO model, you would select FOMO
  • If you uploaded a YOLOv7 model, you would select YOLOv7
  • and so on…
I hope this helps clear up any confusion!
