I’m trying to deploy a simple gesture recognition sketch using Arduino IDE with an ESP32 WROOM board connected via Micro USB. The project reads accelerometer data from an MPU6050 and runs inference using a model exported from Edge Impulse.
The code compiles fine in segments, but when I include my model header file and logic, it fails during compilation with unclear error messages. I’ve tried compiling via Arduino CLI too, but it doesn’t detect the sketch correctly despite correct file structure
[Provide the project ID]
- Verified connections and serial output with a dummy sketch* Imported
leo_16572-project-1_inferencing.hsuccessfully
- Placed
.inofile inside a matching folder (gesture_cli_test_1) - Renamed files correctly and tested in both Arduino IDE and CLI
- Added compile/upload
.batfile — still getting errors or “sketch not found
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
#include <Wire.h>
#include <MPU6050.h>
#include <leo_16572-project-1_inferencing.h>
MPU6050 mpu;
void setup() {
Serial.begin(115200);
Wire.begin();
mpu.initialize();
im trying just the header file its my first project so plz help
