Two-stage system ESP32S3, how to link classifier and detector
ESP32S3 XIAO + Edge Impulse: Cropping image by bounding box after detection
[Provide the project ID]
Hi everyone,
I’m working on a project using two XIAO ESP32S3 boards (Seeed Studio). One device is responsible for object detection, and the other one handles classification.
I’m using Edge Impulse for model deployment. After the detection step, I want to crop the image using the bounding box coordinates before sending it to the second device for classification.
Is there a function or method in the Edge Impulse SDK (or elsewhere) that can crop the original image based on the bounding box and return a new image buffer?
Any guidance or examples would be much appreciated. Thanks!
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [1 ] Always
Hello @Denis552 first of all welcome to the Edge Impulse community!
I don’t think that the Edge Impulse SDK allows you to crop the original image, however i’m sure you can implement it! Let us know if you have any problems creating a function that crops images.
And I have been working with the XIAO ESP32S3 this week and it’s great! So if you can share more details about your use case it will be great!
