Sampling failed
After doing sampling for more than 4 minutes. I confronted this error which I took a PIC. someone knows is it a bug or it is an error due to Arduino 33 BE sens?
[Provide the project ID]
[Provide context or use case where the issue is encountered]
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
Expected Results:
[Describe what you expected to happen]
Actual Results:
[Describe what actually happened]
  • [ ] Always
  • Platform: [e.g., Raspberry Pi, nRF9160 DK, etc.]
  • Build Environment Details: [e.g., Arduino IDE 1.8.19 ESP32 Core for Arduino 2.0.4]
  • OS Version: [e.g., Ubuntu 20.04, Windows 10]
  • Edge Impulse Version (Firmware): [e.g., 1.2.3]
    To find out Edge Impulse Version:
  • if you have pre-compiled firmware: run edge-impulse-run-impulse --raw and type AT+INFO. Look for Edge Impulse version in the output.
  • if you have a library deployment: inside the unarchived deployment, open model-parameters/model_metadata.h and look for EI_STUDIO_VERSION_MAJOR, EI_STUDIO_VERSION_MINOR, EI_STUDIO_VERSION_PATCH
  • Edge Impulse CLI Version: [e.g., 1.5.0]
  • Project Version: [e.g., 1.0.0]
  • Custom Blocks / Impulse Configuration: [Describe custom blocks used or impulse configuration]
    [Include any logs or screenshots that may help in diagnosing the issue]
[Any other information that might be relevant to the issue]
Hello @Edvin_EH2026
First of all, is this related to this topic? Sample time lenght is less than it is expected or you solved that?
Related this this sampling failure i found this topic that maybe can help Arduino Nano 33 Sense: Failed to start sensor fusion sampling - #6 by rujhannajib
Let us know if that works, if not, please do share more logs!
