Sampling failed
After doing sampling for more than 4 minutes. I confronted this error which I took a PIC. someone knows is it a bug or it is an error due to Arduino 33 BE sens?
[Provide the project ID]
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
Expected Results:
Actual Results:
  • [ ] Always
