SAMA7G54 Evaluation kit has 4 pdmc mems microphone, and also SPDIF TX/RX support . But in deployment it shows SAMA7g54 does not have a microphone sensor
Please enable it in deployment tab
[Provide the project ID]
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
- [Step 1]
- [Step 2]
- [Step 3]
Expected Results:
Actual Results:
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
Edge Impulse Version (Firmware): [e.g., 1.2.3]
To find out Edge Impulse Version: - if you have pre-compiled firmware: run edge-impulse-run-impulse --raw and type AT+INFO. Look for Edge Impulse version in the output.
