Process to Deploy a model to STM32L452
What should I read to learn about deploying a model to our custom STM32L452 with accel + gyro board?
I want to provide a development estimate of moving a model tested on an Arduino nano to our
new hardware. Do I need a particular RTOS for optimal performance, etc.
[Provide the project ID]
Detection of Impacts on a lift truck.
  1. made a sample model on a dev kit
  2. [
  3. [Step 3]
  • [ ] Always
Hi @danphelan
You can go with C++ Zephyr Arduino or Arm Keil MDK and open CMSIS route, I believe. @jbuckEI can you advise?
Are you working with sales or one of our solutions engineers on this or do you have a point of contact? Or do you need me to put you in contact with someone?
@yodaimpulse fyi
Eoin,
We are working with Albert Ko and Heath.
Thanks for the information. We have made a few test impulses for our ForkLift impact sensor. My boss wants to use the STM32L452 because we have a good code base already for other IoT cellular products, and we could use it for collecting lots of data from different lifts. I “think” that this MCU will be capable of running the Impulse, but want to find out sooner than later.
I will better define our goals so that EdgeImpulse can help us configure the model better. A tricky part of it is that we dont want to create real Impacts on test lifts. Thought that anomaly detection might help us capture those for model training?
Dan
