Hi! I am a new edge impulse and arduino user and I am having problems with the edge impulse cli. I’ ve just installed the latest python and node updates and when i type “npm install -g edge-impulse-cli” in the cmd I get these errors:
npm ERR! code ENOLOCK
npm ERR! audit This command requires an existing lockfile.
npm ERR! audit Try creating one first with: npm i --package-lock-only
npm ERR! audit Original error: loadVirtual requires existing shrinkwrap file
npm ERR! C:\Users\Iñaki\AppData\Local\npm-cache_logs\2021-05-18T09_41_16_553Z-debug.log
I tried the suggestion ( “npm i --package-lock-only”) and this is what I get :
npm ERR! code EPERM
npm ERR! syscall open
npm ERR! path C:\Windows\System32\package-lock.json
npm ERR! errno -4048
npm ERR! Error: EPERM: operation not permitted, open ‘C:\Windows\System32\package-lock.json’
npm ERR! [Error: EPERM: operation not permitted, open ‘C:\Windows\System32\package-lock.json’] {
npm ERR! errno: -4048,
npm ERR! code: ‘EPERM’,
npm ERR! syscall: ‘open’,
npm ERR! path: ‘C:\Windows\System32\package-lock.json’
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It’s possible that the file was already in use (by a text editor or antivirus),
npm ERR! or that you lack permissions to access it.
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR! C:\Users\Iñaki\AppData\Local\npm-cache_logs\2021-05-18T09_41_25_824Z-debug.log
Hello @louis! Thanks for your answer. unfortunately I still get this:
C:\Windows\System32>npm install edge-impulse-cli -g --force
npm WARN using --force Recommended protections disabled.
added 295 packages, and audited 296 packages in 24s
14 packages are looking for funding
run npm fund for details
5 vulnerabilities (1 low, 4 moderate)
Some issues need review, and may require choosing
a different dependency.
Run npm audit for details.
C:\Windows\System32>npm audit
npm ERR! C:\Users\Iñaki\AppData\Local\npm-cache_logs\2021-05-18T18_42_13_735Z-debug.log
Hello there!! I’ve tried running the command prompt as an admin. It aparently works since I don’t get any more errors with de edge-impulse-cli installation. However, the “edge-impulse-daemon” command is still not recognised as such. This is my command prompt screen.
C:\WINDOWS\system32>npm install -g edge-impulse-cli --force
changed 295 packages, and audited 296 packages in 21s
2 low severity vulnerabilities
C:\WINDOWS\system32>npm audit
found 0 vulnerabilities
C:\WINDOWS\system32>edge-impulse-daemon
“edge-impulse-daemon” no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
Thanks @louis!! the script seems to work fine when it comes to downloading but the edge-impulse-daemon command is still not recognised in the command prompt nor the powershell (I’ve also followed the firmware and arduino-cli instructions).
I finally got it wright!! after following your instructions with the script I just needed to add the edge-impulse-daemon folder to path. Thank you so much @louis
