Problem with generating features
[problem with generating features]
[ 822587]
  1. [creating data set ]
  2. [creating standard impulse]
  3. [while generating features for image processing block i get log : Creating job… OK (ID: 40300302)
Job failed (see above) ]
[generating features]
[job failed]
  • [ *] Always
Today we had an issue where some credentials were not renewed, which affected new jobs (which need those credentials). Unfortunately we only realized this after a few hours as the alerts did not go off properly for this. The issue has been resolved now, and we’ll make sure we’ll get proper monitoring in place in the future. Apologies here (and thanks for reporting).
