I don’t know what to choose for this ESP32-s3 AI cam, OV3660, DFR1154 board.
What should the Espressif ESP-EYE (ESP32 240MHz) target be?
What should I choose in the Deployment target?
What should I choose in the Inference engine?
I want to run a test and detect a pencil or marker.
A zip file is being created, but it doesn’t have the pinouts for this board. Maybe I’m doing something wrong, or this board isn’t implemented?
[Provide the project ID]
1063617
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Platform: [e.g., Raspberry Pi, nRF9160 DK, etc.] ESP32-S3 AI cam
Build Environment Details: [e.g., Arduino IDE 1.8.19 ESP32 Core for Arduino 2.0.4]
Arduino IDE 2.3.10 Board ESP32S3 Dev Module -
OS Version: [e.g., Ubuntu 20.04, Windows 10]
Windows 11 -
Edge Impulse Version (Firmware): [e.g., 1.2.3]
#define EI_STUDIO_VERSION_MAJOR 1
#define EI_STUDIO_VERSION_MINOR 93
#define EI_STUDIO_VERSION_PATCH 27 - Edge Impulse CLI Version: [e.g., 1.5.0]
COde arduino
* SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
// https://github.com/espressif/arduino-esp32/releases/tag/2.0.4
#include <piornik_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define EI_CLASSIFIER_ALLOCATION_TYPE EIDSP_ALLOC_PSRAM
#define CAMERA_MODEL_DFR1154
#if defined(CAMERA_MODEL_DFR1154)
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 5
#define SIOD_GPIO_NUM 8
#define SIOC_GPIO_NUM 9
#define Y9_GPIO_NUM 4
#define Y8_GPIO_NUM 6
#define Y7_GPIO_NUM 7
#define Y6_GPIO_NUM 14
#define Y5_GPIO_NUM 17
#define Y4_GPIO_NUM 21
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 16
#define VSYNC_GPIO_NUM 1
#define HREF_GPIO_NUM 2
#define PCLK_GPIO_NUM 15
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
//.pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
.frame_size = FRAMESIZE_QVGA, //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
.fb_count = 1, //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
Serial.begin(115200);
Serial.printf("PSRAM total: %d\n", ESP.getPsramSize());
Serial.printf("PSRAM free: %d\n", ESP.getFreePsram());
Serial.printf("Heap free: %d\n", ESP.getFreeHeap());
while (!Serial);
else {
ei_sleep(2000);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
return;
Serial.printf("Free PSRAM: %u\n", ESP.getFreePsram());
Serial.printf("Free Heap: %u\n", ESP.getFreeHeap());
snapshot_buf = (uint8_t*)ps_malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
if(snapshot_buf == nullptr) {
return;
ei::signal_t signal;
free(snapshot_buf);
return;
// Run the classifier
Serial.printf("Before classifier PSRAM free: %d\n", ESP.getFreePsram());
Serial.printf("Before classifier Heap free: %d\n", ESP.getFreeHeap());
Serial.printf("Arena size: %d\n", EI_CLASSIFIER_TFLITE_LARGEST_ARENA_SIZE);
Serial.printf("signal length=%d\n", signal.total_length);
Serial.printf("arena=%d\n", tflite_learn_1063617_3_arena_size);
if (err != EI_IMPULSE_OK) {
free(snapshot_buf);
return;
// print the predictions
ei_printf("Object detection bounding boxes:\r\n");
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#else
ei_printf("Predictions:\r\n");
ei_printf(" %s: ", ei_classifier_inferencing_categories[i]);
ei_printf("%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
ei_printf("Visual anomalies:\r\n");
for (uint32_t i = 0; i < result.visual_ad_count; i++) {
ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
continue;
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#endif
free(snapshot_buf);
* @brief Setup image sensor & start streaming
* @retval false if initialisation failed
bool ei_camera_init(void) {
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
if (err != ESP_OK) {
return false;
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
s->set_vflip(s, 1);
s->set_awb_gain(s, 1);
#endif
is_initialised = true;
return true;
* @brief Stop streaming of sensor data
void ei_camera_deinit(void) {
//deinitialize the camera
if (err != ESP_OK)
ei_printf("Camera deinit failed\n");
return;
return;
* @brief Capture, rescale and crop image
* @param[in] img_width width of output image
* @param[in] img_height height of output image
* @param[in] out_buf pointer to store output image, NULL may be used
* if ei_camera_frame_buffer is to be used for capture and resize/cropping.
* @retval false if not initialised, image captured, rescaled or cropped failed
bool do_resize = false;
if (!is_initialised) {
return false;
if (!fb) {
return false;
bool converted = fmt2rgb888(
fb->buf,
fb->len,
PIXFORMAT_JPEG,
snapshot_buf
esp_camera_fb_return(fb);
if (!converted) {
ei_printf("RGB conversion failed\n");
return false;
do_resize = true;
if (do_resize) {
snapshot_buf,
EI_CAMERA_RAW_FRAME_BUFFER_COLS,
out_buf,
img_width,
img_height);
return true;
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
// Swap BGR to RGB here
// due to https://github.com/espressif/esp32-camera/issues/379
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
#endif
