Kindly help me in troubleshooting connection between esp32 and edge impulse
Greetings electrical engineers, it is requested to tell me that why is this problem coming repeatedly?
Connecting to COM10
Hi @TKHOWAREYOU,
Which ESP32 board are you using? Please note that we only officially support the ESP-EYE with the edgeimpulse cli tool. If you are using the ESP-EYE, please make sure you have uploaded the Edge Impulse firmware to it as per these instructions: https://docs.edgeimpulse.com/docs/development-platforms/officially-supported-mcu-targets/espressif-esp32
If that does not work, please see these other threads that might offer some insights:
Did you run flash_windows.bat? It looks like the daemon can’t understand what the device it outputting so its not an electrical issue…more of a firmware issue.
