Improving accuracy on npd120 model
Even after adding an external dataset my accuracy is below 40%
[Provide the project ID]
AS4065U-project-1
  1. [Step 1] Made my own dataset
  2. [Step 2] Downloaded an external dataset
  3. [Step 3] Added my recordings to the dataset downloaded
I would like my accuracy to be closer to 100%.
The accuracy is below 40% no matter the changes
  • [X] Always
    Arduino Nicla Voice
    Arduino IDE
    Windows 11 Home
    Dataset MLend_numbers
Have you had a look at the Training Graphs for your model (available on the Model Training screen) New in Studio: Training Graphs (yes… finally!) and TensorBoard Integration
These might give you an insight into whether your model training is converging or if it may need longer training (more epochs).
The other useful tool is to look at the data explorer: Data explorer - Edge Impulse Documentation
If your dataset is not well separated into clusters it may be that your data is of poor quality.
The MLend dataset is very big so it’s more than likely that you’ll need longer to train (higher epochs) to get a good quality model.
Finally- how have you set up your Impulse? Is your chosen window size big enough to match the length of the audio events (spoken words?) you’re trying to detect? If you’re trying to detect a word that takes 1 second to say with a window size of 300ms you’ll struggle to train an accurate model because the training data will be chopped up and you’ll lose the entire words.
