I can not scan the Qr code in the connect device phone section
[* can not scan the Qr code in the connect device phone section*]
[Provide the project ID]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
Hi @Demanico - are you still having this issue?
If so, I would need some more information to look into it. Specifically, is this happening on a single project or all of your projects? Do you have the project ID (can be found at the end of the URL when you are viewing your project)?
