How to apply my CSV specification to label my data using CSV Wizard?
Apologize if it is an easy question.
I am new and trying to train using N number of image files. The image files are named blobs.1.png, blobs.2.png, and so on. The CSV file has the following format.
file_name,this_feature
blobs.1.png,8
blobs.2.png,2
blobs.3.png,4
blobs.4.png,1
I have already uploaded the CSV file through CSV wizard. How do I automatically apply ‘this_feature’ as the label to the uploaded data? The objective is to create a model that will predict ‘this_feature’ as the output for an input image.
This is not time-series data. Whenever I upload new dataset, it asks me if it should infer the data from the filenames (not true), should keep the label empty, or provide a manual label. But it does not ask if it should consult the active csv configuration.
I am new to this. Please help.
The context is to train a model to learn about a feature of images in a dataset.
See above.
I will provide the CSV file and the uploaded dataset will be automatically labelled using the CSV file.
Either wrong label (only the column header) or nothing.
  • [ x] Always
None.
The CSV wizard is for defining non-standard time-series structures: CSV Wizard - Edge Impulse Documentation
It isn’t possible to use the CSV wizard for your purposes unfortunately.
If you want to upload a file which specifies the labels of your data I suggest using the info.labels json structure which we support for classification or object detection labelling of images : Edge Impulse labels - Edge Impulse Documentation
