I have downloaded the code from edge impulse.I want now to flash it in raspberry pi model 4. Can anyone provide the clear guide to flash it.
[Provide the project ID]
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
