Filtering dataset for training/export — is it supported?
I need to export and train only on the labeled images in my dataset (Bee / Hornet / Wasp). Only filtered data?
The goal of my project is to classify or detect different insects (Bees / Hornets / Wasps).
The dataset provided contains many frames, including unlabeled ones.
To improve training quality, I need to isolate only the labeled samples.
But Edge Impulse currently treats filters as visual-only, so I cannot export or train on only the labeled subset.
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
In similar cases when I’ve wanted to exclude part of the data during training, without deleting it, I’ve disabled it in data acquisition. Click on the 3 dots at the right of a sample and choose Disable, or multi-select many samples and click the button Disable.
