I am on the project for motion detection and this below Picture is the feature extraction window. From my prespective , there is a problem since the axis are not availble. I can not manipulat the axis to see which feature has more prevelege. For more clarification, I am using an Arduino BLE 33 nano rev2 with a dc Motor amature. Someone knows where the problem is ?
[Provide the project ID]
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
