Error : invalid model for current sensor
I try to deploy a model on Arduino Nano 33 BLE rev2 regarding motion detection. But I faced an error which says invalid model for current sensor. I have already checked the library of Edge impulse which the sensor is defined. (model_metadata.h). anyone knows how I can resolve it ?
[Provide the project ID]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
hi @Edvin_EH2026 !
you have both accelerometer and gyroscope data in your project, you need to use sensor fusion sketch example.
Let me know if it fixes the issue!
Yes.it worked. thank you so much
