Hi Aurelien,
Thank you for the quick reply. I ran the command as shown as following:
npm config set user root && sudo npm install edge-impulse-linux -g --unsafe-perm
It still shows me the error.
Terminal output:
pi@raspberrypi:~ $ npm config set user root && sudo npm install edge-impulse-linux -g --unsafe-perm
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm ERR! code 1
npm ERR! path /home/pi/.npm-global/lib/node_modules/edge-impulse-linux/node_modules/sharp
npm ERR! command failed
npm ERR! command sh -c (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
npm ERR! sharp: Are you trying to install as a root or sudo user? Try again with the --unsafe-perm flag
npm ERR! sharp: Please see https://sharp.pixelplumbing.com/install for required dependencies
npm ERR! sharp: Installation error: EACCES: permission denied, mkdir ‘/root/.npm’
npm ERR! /root/.npm/_logs/2022-01-05T23_11_49_893Z-debug.log
pi@raspberrypi:~ $ sudo mkdir -p /root/.npm
npm ERR! code 1
npm ERR! /root/.npm/_logs/2022-01-06T23_26_13_452Z-debug.log
EACCES corresponds to incorrect permissions and may hint to incorrect node (and package) installation on your system. I can see in your logs different paths, /home/pi/.npm-global/ and root/.npm. Check whether the directories have the right permissions for the current user.
You may also want to look into NVM for a better experience install Node (packages).
