Error Cloning Public Project: "Cannot read properties of undefined (reading 'filter')"
Cannot read properties of undefined (reading ‘filter’)
Job failed
[Provide the project ID]
Summary:
[Provide a concise summary of the bug]
Steps to Reproduce:
1. Opened Edge Impulse Studio
2. Clicked “Clone project”
3. Entered the public project link or imported the project package
4. Started cloning
Expected Results:
:heavy_check_mark: Job scheduled at 30 Jun 2025 03:35:08
:heavy_check_mark: Job started at 30 Jun 2025 03:35:10
[2/8] Downloading version…
Downloading 103841/versioning/v3.zip…
Downloading 103841/versioning/v3.zip OK
[2/8] Downloading version OK
[3/8] Extracting version archive…
43%
100%
[3/8] Extracting version archive OK
[4/8] Copying back project files…
0% (0 MB copied)
100% (35 MB copied)
[4/8] Copying back project files OK
[5/8] Restoring project and impulse config…
Job failed (see above)
Actual Results:
  • [ -] Always
Hi @joon2ran, thanks for reporting - we’re investigating.
Hi @joon2ran The job you linked is from 30 June (about a month ago), we fixed this issue on July 2nd… If you do a fresh clone of the project this should be resolved (if you go to the previously created clone you’ll see the old logs - it won’t reclone).
edit: Apparently this question was stuck in the review code for a month and just got unblocked, apologies.
