When running Eon Tuner, I receive multiple logs (>50) as the one shown bellow, and the searching process fails:
“WARN: failed to process 735229/split/r2b_vibracao_carcaca_e_Ia_torque_40_ensaio_10.s2.json.5v5gq9cn.ingestion-7d8b657c77-bmm5g.json: Cannot process file, impulse requires axis “csv”, but not present in this file (found: “Vibracao”, “Corrente”) - note: axes are case sensitive.”
It happens whenever I try to use my data (that I upload through csv wizard).
Summary:
Eon Tuner fails because the impulse expects axis "csv", but the uploaded data via CSV Wizard has axes "Vibracao" and "Corrente" (case-sensitive mismatch).
Steps to Reproduce:
- Upload data through csv wizard (each file has 2 columns of data)
- Select, in the DSP blocks, only one data column
- Run Eon Tuner
Expected Results:
Eon Tuner should complete its search.
Actual Results:
Eon tuner fails in each search trial.
- [ X] Always
- [ ] Sometimes
- [ ] Rarely
Edge Impulse Version (Firmware): [e.g., 1.2.3]
To find out Edge Impulse Version: - if you have pre-compiled firmware: run edge-impulse-run-impulse --raw and type AT+INFO. Look for Edge Impulse version in the output.
