I’m having a problem where my Edge Impulse is not recognized. I did both way installation
the npm install edge-impulse-cli -g --force and follow the Github version, but no luck for me none of them works, Im suspecting the PATH could be an issue.
Here’s the snapshot of the picture for the Github way installation. Still failed. Wish anyone here could help me
Did you install the “Additional Tools for Node.js” during Node.js installation? If not, you should be able to run them by searching for them in the Windows search bar. If that does not work, you may need to uninstall npm and node.js and reinstall from the beginning.
I recommend looking through these threads to see if any of the comments in there help:
