help me to connect nano 33 ble sense rev2 to edge impulse
Hi @GANESHA ,
You may need to reinstall node.js or click “Additional Node.js tools” during the node.js installation process. Please refer to the following threads to see if any of the solutions presented there help resolve the issue:
When trying to install Edge Impulse CLI using Nano 33 BLE sense, the error below appears.
Node.js is installed, Python 3 is installed.
Why is this error coming out?
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated reques…
I have a problem to install Edge Impulse CLI tools, the prompt shows me an error saying that request for node.js is not longer available.
Also I cannot run the Impulse daemon
npm install -g --force edge-impulse-cli
npm WARN using --force I sure hope you know what you are doing.
npm ERR! code 1
npm ERR! path C:\Users\User\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@8.2.0
npm ERR! gyp info using node@16.13.0 | win32 | x64
npm ERR! gyp info find Python using Python version 3.10.0 found at “C:\Users\Us…
Facing issue with installation of Edge impulse CLI tool. Below are the logs of installation procedure
C:\Windows\System32>npm install -g edge-impulse-cli --force
npm WARN using --force Recommended protections disabled.
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends th…
