Facing issue with installation of Edge impulse CLI tool. Below are the logs of installation procedure
C:\Windows\System32>npm install -g edge-impulse-cli --force
npm WARN using --force Recommended protections disabled.
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1.
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.0: request has been deprecated, see
npm ERR! code 1
npm ERR! path C:\Users\emqos\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@8.4.1
npm ERR! gyp info using node@16.14.0 | win32 | x64
npm ERR! gyp info find Python using Python version 3.10.2 found at “C:\Python310\python.exe”
npm ERR! gyp ERR! find VS
npm ERR! gyp ERR! find VS msvs_version was set from command line or npm config
npm ERR! gyp ERR! find VS - looking for Visual Studio version 2019
npm ERR! gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
npm ERR! gyp ERR! find VS checking VS2022 (17.0.32126.317) found at:
npm ERR! gyp ERR! find VS “C:\Program Files\Microsoft Visual Studio\2022\Community”
npm ERR! gyp ERR! find VS - found “Visual Studio C++ core features”
npm ERR! gyp ERR! find VS - found VC++ toolset: v143
npm ERR! gyp ERR! find VS - found Windows SDK: 10.0.19041.0
npm ERR! gyp ERR! find VS - msvs_version does not match this version
npm ERR! gyp ERR! find VS checking VS2019 (16.11.32106.194) found at:
npm ERR! gyp ERR! find VS “C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools”
npm ERR! gyp ERR! find VS - missing any VC++ toolset
npm ERR! gyp ERR! find VS checking VS2017 (15.9.28307.1800) found at:
npm ERR! gyp ERR! find VS “C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools”
npm ERR! gyp ERR! find VS - found VC++ toolset: v141
npm ERR! gyp ERR! find VS - found Windows SDK: 10.0.17763.0
npm ERR! gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
npm ERR! gyp ERR! find VS looking for Visual Studio 2015
npm ERR! gyp ERR! find VS - not found
npm ERR! gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
npm ERR! gyp ERR! find VS valid versions for msvs_version:
npm ERR! gyp ERR! find VS - “2022”
npm ERR! gyp ERR! find VS - “C:\Program Files\Microsoft Visual Studio\2022\Community”
npm ERR! gyp ERR! find VS - “2017”
npm ERR! gyp ERR! find VS - “C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools”
npm ERR! gyp ERR! find VS **************************************************************
npm ERR! gyp ERR! find VS You need to install the latest version of Visual Studio
npm ERR! gyp ERR! find VS including the “Desktop development with C++” workload.
npm ERR! gyp ERR! find VS For more information consult the documentation at:
npm ERR! gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
npm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Could not find any Visual Studio installation to use
npm ERR! gyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:122:47)
npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:75:16
npm ERR! gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:363:14)
npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:71:14
npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:384:16
npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:406:5)
npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:520:28)
npm ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1092:16)
npm ERR! gyp ERR! System Windows_NT 10.0.19042
npm ERR! gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
npm ERR! gyp ERR! cwd C:\Users\emqos\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings
npm ERR! gyp ERR! node -v v16.14.0
npm ERR! gyp ERR! node-gyp -v v8.4.1
npm ERR! gyp ERR! not ok
npm ERR!     C:\Users\emqos\AppData\Local\npm-cache_logs\2022-02-14T09_54_27_379Z-debug-0.log
I have installed python and node.js (even installed additional tool also) and Visual studio tools installed also shown in below image.
Executing  “npm install -g edge-impulse-cli --force” comand in node.js command prompt.
Please let me know whats the issue and solution for it.
