I am in China. Cannot install the latest Edge Impulse CLI due to the network block of sharp. And I can only install version 1.14.10 by far. When I connect the board with daemon, it said that the firmware is AT 1.8.0 while my version only supports 1.7.X. I cannot find AT 1.7.X to update the firmware and update CLI still caused error.
[SER] Connecting to COM3
Failed to parse snapshot line [ ]
[SER] Retrieved configuration
[SER] Device is running AT command version 1.8.0
[SER] Unsupported AT command version running on this device. Supported version is 1.7.x and lower, but found 1.8.0.
[SER] Update the Edge Impulse CLI tools (via npm update edge-impulse-cli -g) to continue.
PS C:\Users\Lu> edge-impulse-run-impulse
Edge Impulse impulse runner v1.14.10
? Which device do you want to connect to? COM3 (Microsoft)
[Provide the project ID]
- [Step 1]
- [Step 2]
- [Step 3]
- [ ] Always
- [ ] Sometimes
- [ ] Rarely
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
