Change TensorRT model in Jetson Nano
I want to use a new model of TensorRT library
[Provide the project ID]
I have a Jetson Nano where I ran a project using the TensorRT library in Deplyment. The issue is that I train another model with different pictures to be identified in the inference, but I don’t know now how to replace the old model by the new model that I download as TensorRT library.
It has been a long time since I install the old model that I don’t know how to install the new one. I guess that I have to replace de /build/model.eim but I don’t know how to build the new one.
I place the 3 folder created at edge impulse in the place of where the 3 old ones are.
I execute: APP_EIM=1 TARGET_JETSON_NANO=1 CC=clang-17 CXX=clang+±17 make -k
The /build/model.eim was not updated
I would like the steps to follow to install the TensorRT library and replace the old one. I want to get rid of the old model.
No modifications in the old /build/model.eim
  • [ ] Always
@Mikel,
After replacing the 3 folders (from your Edge Impulse TensorRT Library deployment) can you try the following:
APP_EIM=1 TARGET_JETSON_NANO=1 CC=clang CXX=clang++ make clean
Thank you @rjames!!!
With your commands it works!
