Audio classification using ESP32 and INMP441 microphone to detect faucet-ON. Training on EdgeImpulse using MFCC and KERAS Classifier
Question/Issue
I have 24 hours and I must setup ESP32 with INMP441 microphone. I want to show how I can train the model to classify faucet-ON and wish to turn-ON an LED on my bread board during inferencing when the microphone listens into faucet sound.
Since I do not see the ESP32 in the list of devices, only the ESP-EYE, I am progressing.
but i need some guidance on how to get the EdgeImpuse to hear from my INMP441 connected to the ESP32 adn through the c-cable to my laptop
  1. ESP and INMP and LED connected correctly on the breadboard.
  2. Edge Impulse setup and Data acquisiton and Impulse design done.
  3. unsure of how to perform Live classification, and later how to push this to ESP32 ?
ESP32 with INPM441, listens into live water-flowing and classifies audio = FAUCET-ON.
and this lights-up the LED on the bread-board.
have soem knowlege gap
  • [ ] Always
Hello @denny.mbzuai,
If you are familiar with Arduino IDE and sketches, you can also download an Arduino Library in the Deployment section of your Edge Impulse project.
We provide by default a few example available in the Arduino IDE after you import the library. You can then customize the sketches to your need.
If you prefer the ESP-IDF route, you can also use our C++ Library. You’ll find more info here: GitHub - edgeimpulse/example-standalone-inferencing-espressif-esp32: Builds and runs an exported impulse locally (ESP IDF)
Let us know how it goes!
I created a GitHub repo to document my steps for building an ESP32 + INMP441 keyword-spotting model. It might also work for detecting the water-flowing sound you mentioned—you would just need enough training and testing data for the specific audio you want to classify.
