Arduino nano code
I downloaded arduino code for edge impulse which is compatible to nano, I ma not able to run in UNO.?
[Provide the project ID]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
Hi @Anuprash
The Uno is not supported, some community members have posted and used it successfully with the Arduino Library Arduino library | Edge Impulse Documentation
Although its best to go for a recommended device for best results
Hi @Eoin Thankyou for replying.
I got hold of Raspberry pi 4 MODEL B, I want to deploy the code from edge impulse and run it locally without internet.I went to the documentation section but didnot get much info.Can you help me here.
