Arduino Nano BLE 33 rev2 deploy as a pre-built firmware
[Hi everyone, I follow the deployment by Deployment | Documentation , when I click building and started to run in cmd.exe, but it shows failed to get info off device Timeout when waiting for > (timeout: 5000) on Connected, how can I solve it? Thank you]
[432317]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
