Adafruit I2S microphone with raspberry pi on raspbian
I have a project for key word spotting and i am using adafruit SPH0645 mems mic, it supports 44.1 KHz sampling rate and designated device tree fro it is google voice hat dac device tree, but when I run the edge impulse model it says this mic is not supported I want to know how can I make edge impulse use this device for wake up word detection.
[Provide the project ID]
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
  • [ ] Always
Hello @MGE_GOAT first of all welcome to the Edge Impulse community!
Could you please share more details of the exact hardware or system that you are using (as defined in the template)?
Share as well some logs that you get, so we can help you more!
