[Why doesn’t edge impulse detect accelerometer connect to pico? In “Data acquisition”, under Sensor, I only see built-in microphone, ultrasonic ranger, ADC Sensor and Ultrasonic ranger + ADC sensor but not accelerometer. I’m expecting accX, accY and accZ values that I don’t find here. ]
[pico_ADXL335]
- [Step 1]
- [Step 2]
- [Step 3]
[I’m expecting accX, accY and accZ values that I don’t find here. ]
[In “Data acquisition”, under Sensor, I only see built-in microphone, ultrasonic ranger, ADC Sensor and Ultrasonic ranger + ADC sensor but not accelerometer.]
- [x ] Always
- [ ] Sometimes
- [ ] Rarely
- Platform: [e.g., Raspberry Pi Pico]
- OS Version: [MS Windows]
- Edge Impulse Version (Firmware): [e.g., 1.2.3]
