I am new user using EdgeImpulse I have a time series csv file
num, col, row, inpx, inpy, angx, angy, X,Y,Tilt,A
num is the receive data number
col,row inpx,inpy angx,angy is input data
X,Y Tilt,A is ouput data
Could you help me how to set up the multi label data?
- CSV wizard
- upload the my data include .jason file
- jason file fail to upload
the data still has one label call X other Y , AZ and tile are not included
- [X ] Always
- [ ] Sometimes
- [ ] Rarely
Platform: [e.g., Raspberry Pi, nRF9160 DK, etc.]
Build Environment Details: [e.g., Arduino IDE 1.8.19 ESP32 Core for Arduino 2.0.4]
OS Version: [e.g., Ubuntu 20.04, Windows 10]
Edge Impulse Version (Firmware): [e.g., 1.2.3]
Edge Impulse CLI Version: [e.g., 1.5.0]
Project Version: [e.g., 1.0.0]
Hello @hwtseng1976 first of all welcome to the Edge Impulse community!
I see that your issue is related on uploading the csv. Do you need to use JSON on your data?
Related to the multi label data, did you read the multi-label data docs we have here? Multi-label data - Edge Impulse Documentation
Please share more details on how do you need to label your data? Feel free to share more details so we will be able to help you more!
Thanks!
Thanks, Finally we apply Keras expert mode to enable multi ouput machine learning.
- define the map function
def reformat_data(features, labels):
new_features = tf.cast(features[:16], tf.float32)
強制將所有參與拼接的數值轉為 float32
new_labels = tf.concat([
tf.cast(tf.reshape(labels, [1]), tf.float32),
tf.cast(features[16:19], tf.float32)
], axis=0)
return new_features, new_labels
- map the data in the correction postion
This is False by default.
ENSURE_DETERMINISM = args.ensure_determinism
this controls the batch size, or you can manipulate the tf.data.Dataset objects yourself
BATCH_SIZE = args.batch_size or 32
if not ENSURE_DETERMINISM:
train_dataset = train_dataset.shuffle(buffer_size=BATCH_SIZE*4)
train_dataset = train_dataset.map(reformat_data)
validation_dataset = validation_dataset.map(reformat_data)
train_dataset=train_dataset.batch(BATCH_SIZE, drop_remainder=False)
validation_dataset = validation_dataset.batch(BATCH_SIZE, drop_remainder=False)
- change the model as 16 input and 4 output
- change the loss function based on the requiremnet and print the mse for the 4 ouput.
- use TensorBoard to check the MSE V.S. Epoch
Thanks for sharing your solution @hwtseng1976
Let us know if you have any other questions!
