Unable to run model on Jetson Orin Nano
Unable to run keyword spotting model on Jetson Orin Nano
I am trying to use edge-impulse-linux-runner to run the model on my Orin Nano.
  1. successfully built model in Edge Impulse project
  2. Started a jetson-container Docker container
  3. installed edge-impulse-linux within the container: wget -q -O - https://cdn.edgeimpulse.com/firmware/linux/orin.sh | bash
Expected to run the model and test the keyword spotting functionality
root@jetson-nano:/sambashare# edge-impulse-linux-runner
Edge Impulse Linux runner v1.15.2
[RUN] Downloading model…
[RUN] Downloading model OK
[RUN] Failed to run impulse Failed to start runner (code: 127): /tmp/tmp/ei-1750187310932Cvzfto/runner-linux-aarch64-jetson-orin: error while loading shared libraries: libcudart.so.11.0: cannot open shared object file: No such file or directory
The jetson container for Jetpack 6.2 has a newer version of libcudart
  • [x] Always
  • Platform: Jetson Orin Nano dev board
  • Build Environment Details: Jetpack 6.2, Jetson-Container
  • OS Version: Ubuntu 22.04
Is it possible to run the impulse in the jetson container that was built for Jetpack 6.2?
Hi @ericr
Thanks for the detail, and welcome to the forum, it looks like you’re encountering a compatibility issue between the Edge Impulse runner binary and JetPack 6.2. The runner expects libcudart.so.11.0, but JetPack 6.2 includes a newer CUDA version (e.g., libcudart.so.12), causing a runtime error.
Can you try to use the 6.0 or 5.1.2 JetPack?
JetPack
For NVIDIA Jetson Orin:
see - NVIDIA Jetson | Edge Impulse Documentation
Let me know if you need help with downgrading the Jetpack version, cc: @rjames
I see. Something I had read made me think Edge Impulse would work with JetPack 6.2 as well. Is there any plan to support JetPack 6.2 any time soon?
