Thingy 53 How to constanly measure data and acces it from a distance
I want to use a Thingy:53 to automatically collect data inside a transformer cabinet. I need to measure both environmental data and vibrations, and I want these measurements to be sent directly to my Edge Impulse project. The problem is that I can’t find a reliable way to automate the measurements and transmit the data over a long distance.
Context / Use case:
The Thingy:53 will be placed inside a closed transformer cabinet and should periodically record sensor data. The device needs to send this data to Edge Impulse without requiring any physical access.
  1. Connected the Thingy:53 to Edge Impulse via BLE/USB for local testing.
  2. I have tried to program the thingy with the nrf desktop app, i wanted to make a loop so the device would constantly start measuring when it is turned on
The Thingy:53 should automatically record sensor data and send it to Edge Impulse through a suitable wireless method that works over a long distance.
The Thingy:53 only works when it is close to a laptop/phone (BLE), and I haven’t found a way to transmit data to Edge Impulse over a larger distance.
  • Always
  • Platform: Nordic Thingy:53
  • Build Environment Details: [e.g., nRF Connect SDK version / firmware version]
  • OS Version:
  • Edge Impulse Version (Firmware):
  • Edge Impulse CLI Version:
  • Project Version:
  • Custom Blocks / Impulse Configuration: Standard sensor configuration (environment + accelerometer).
BLE has a limited range and requires some kind of host device to then forward data on to Edge Impulse.
Nordic does also provide a WiFi module for the Thingy:53 which could enable remote data collection without needing a host device. This could solve your problem:
https://www.nordicsemi.com/Products/Development-hardware/nRF7002-Expansion-Board
