Hi!I need some help.
Now I have trained a voice model on the edge ipulse that can recognize the “light on” and “light off” instructions. Now I want to call this model on Arduino IDE and write a program to control the LED on or off of Arduino nano 33 ble sense development board. After I follow the steps in the document to convert the pulse into C + + source code, I don’t know how to take the next step. I hope you can give me some advice. What can I do next?
Hi @Joker,
I used the nano_ble33_sense_microphone_continous.ino
example.
You can add something similar to this in the loop function :
void loop()
if (!m) {
return;
signal_t signal;
signal.total_length = EI_CLASSIFIER_SLICE_SIZE;
signal.get_data = µphone_audio_signal_get_data;
ei_impulse_result_t result = {0};
EI_IMPULSE_ERROR r = run_classifier_continuous(&signal, &result, debug_nn);
if (r != EI_IMPULSE_OK) {
return;
if (++print_results >= (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)) {
// print the predictions
ei_printf("Predictions ");
ei_printf(": \n");
ei_printf(" %s: %.5f\n", result.classification[ix].label,
if(result.classification[2].value>CMD_THRESHOLD){
ei_printf("Turning off the leds \n");
// turn the LED on (HIGH is the voltage level)
digitalWrite(RED, LOW);
digitalWrite(GREEN, LOW);
digitalWrite(BLUE, LOW);
digitalWrite(LED_PWR, HIGH);
if(result.classification[5].value>CMD_THRESHOLD){
ei_printf("Turning on the leds \n");
digitalWrite(RED, HIGH);
digitalWrite(GREEN, HIGH);
digitalWrite(BLUE, HIGH);
digitalWrite(LED_PWR, LOW);
#endif
print_results = 0;
Change the result.classification[2]
with the right index of the keyword you want to detect (in my case the word up
is at the index 2 and the word down
is at the index 5).
And do not forget to define your LEDs and the threshold you want at the beginning of your Arduino sketch:
// Define LED
#define RED 22
#define BLUE 24
#define GREEN 23
#define LED_PWR 25
#define CMD_THRESHOLD 0.8
And it is always a good practice to initialise the digital pins in the setup
function:
//Initialize digital pin as an output for the LED
pinMode(RED, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(LED_PWR, OUTPUT);
Best regards,
Hello @Joker,
Can you try to select the Arduino Nano 33 BLE instead of the Arduino Uno please?
If I try to compile an audio classification project by selecting the Arduino Uno board, I get this error:
However, if I select the Arduino Nano 33 BLE, it works fine:
Hello, sir. I want to express my gratitude to you. With your help, I have solved this problem now, and the project I created can work normally. Thank you very much for your help.
