I’m attending the Sparkfun “AI Workshop: Muscle AI” workshop and want to make sure that my system is set up right before the workshop starts.
I added a new board “Sparkfun Micromod nRF52840 Processor” to the Arduino IDE by following this guide. When trying to compile “Blinky”, the compiler fails with:
arm-none-eabi-g++: error: softfp: No such file or directory
arm-none-eabi-g++: error: fpv4-sp-d16: No such file or directory
exit status 1
Error compiling for board SparkFun MicroMod nRF52840 Processor Board.
The guide talks about a Arduino Nano 33 BLE library with version 1.3.1 which I should modify, but by now the library are version 2.2.2 which indicates some breaking changes. Can someone confirm it’s possible to compile with version 2.2.2 of the library?
I’m not sure if this is a general issue or just on my machine. I installed some custom GCC ARM compilers with Homebrew and also some packets in VSCode, so I’m used to sometimes having compilers get a hiccup. I reinstalled Arduino and all libraries, removed my homebrew ARM GCC toolchain and my VSCode plugins, but nothing had any effect.
Any idea what I could do?
I’m on macOS 11.4 Big Sur.
Thanks for the quick answer Louis! Alright then I don’t need to do anything to prepare anymore, I’ll just drop in that folder with the 1.3.1 version once you provide it.
Looking forward to the session! Thank you for organizing this
I installed the CLI packages; when I tried testing the installation by running ‘edge-impulse-daemon’ on the command prompt, I got an error message saying the application ‘could not locate the bindings file’, and it gave me a list of nodes it tried.
The edge-impulse-uploader worked; but I got the same error (‘could not locate the bindings file’) when I tried executing the ‘edge-impulse-run-impulse’ app.
I am running this on Windows 10, with NodeJS and Python installed at the standard paths.
I had another issue when I tried that, in that after uninstalling the older version, I couldn’t install the CLI with the updated NodeJS 16.
I opened another thread describing the issues I had; I found a solution for the installation / setup issues by updating the version for Visual Studio (2019) and the path for the Python executable in my system for node-gyp: see this thread – Installing Edge Impulse CLI - Help - Edge Impulse
Hello - I have received my kit and I’m looking forward to the workshop tomorrow.
So far I have successfully got the board working with the Arduino IDE as per the Sparkfun guide.
I am using Windows 10, and have successfully installed Python, Node.js and the Edge Impulse CLI - however I am getting stuck trying to get the Edge Impulse daemon working with the Sparkfun board:
C:\Users\darre>edge-impulse-daemon
Edge Impulse serial daemon v1.13.8
Endpoints:
? Which device do you want to connect to? COM3 (Microsoft)
[SER] Connecting to COM3
COM3 is the correct port, as I used that with the Arduino IDE (which was not running while I ran the edge-impulse-daemon).
Edge Impulse Daemon won’t work here because the MicroMod board is not officially supported by Edge Impulse, but we will see together how to use the edge-impulse-data-forwarder to collect the data
Yes you could although the arduino sketches won’t be compatible as I will be using the a specific library for the accelerometer.
But you will be able to use the default example from the Edge Impulse default library. And it will be easily adaptable to use the BLE for the last part.
Hi Louis. Thank you. I was just about to ask if a new boot loader will be provided and used in this WS, or we are going to use the data-forwarder option.
We won’t be using the daemon but if you want to test the CLI is actually installed, you can run:
edge-impulse-daemon
Edge Impulse serial daemon v1.13.6
Endpoints:
[SER] Could not find any devices connected over serial port
[SER] Retrying in 5 seconds
