Seeed Grove Vision AI Module V2 - Collect Data - "sample length max allowed 0ms
On Ubuntu 24.01 connecting to Grove Vision AI Module V2 via edge-impulse-daemon, device is shown in device list. Collect-Data for camera seems to work. Collect data for microphone fails with error message “Failed to start sampling - sample length is too long, maximum allowed 0 ms”.
Changing to 0ms triggers sampling at the device - but returns no data :slight_smile:
Want to use the board for voice-sampling.
Summary:
Error message on start of sampling via microphone:
Steps to Reproduce:
  1. Connect device via command-line
    2.Check device is visible
  2. Data collection for microphone
Expected Results:
Sampling to start
Actual Results:
When using with “0” connections works, but doesnt sample anything :slight_smile:
  • [x] Always
Ubuntu 24.01 LTS
Log
From a sampling request with sample length=0
`[WS ] Incoming sampling request {
path: ‘/api/training/data’,
label: ‘GoodWatch’,
length: 0,
interval: 0.0625,
hmacKey: ‘05bb29fd95e125b7576d0fbad943a00e’,
sensor: ‘Microphone’
[SER] Configured upload settings
[SER] Sampling started
[SER] Sampling done
[SER] Device not connected to WiFi directly, reading from buffer (bytes 0 - 172, expecting to read ~229 bytes…
[SER] Reading from buffer OK
[SER] File is 172 bytes after decoding
[SER] Uploading to https://ingestion.edgeimpulse.com/api/training/data
[SER] Failed to upload to https://ingestion.edgeimpulse.com/api/training/data StatusCodeError: 400 - “Payload is missing, or payload length is 0”
at new StatusCodeError (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request-promise-core/lib/errors.js:32:15)
at plumbing.callback (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request-promise-core/lib/plumbing.js:104:33)
at Request.RP$callback [as _callback] (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request-promise-core/lib/plumbing.js:46:31)
at self.callback (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request/request.js:185:22)
at Request.emit (node:events:519:28)
at Request. (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request/request.js:1161:10)
at IncomingMessage. (/home/development/.nvm/versions/node/v21.6.1/lib/node_modules/edge-impulse-cli/node_modules/request/request.js:1083:12)
at Object.onceWrapper (node:events:633:28)
at IncomingMessage.emit (node:events:531:35)
at endReadableNT (node:internal/streams/readable:1696:12)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
statusCode: 400,
error: ‘Payload is missing, or payload length is 0’,
options: {
headers: {
‘x-api-key’: ‘ei_cdd32720e0ce0c2db0cad1808ebffed94fd9b84d09087c9a4a67b7f91dfd2f45’,
‘x-file-name’: ‘GoodWatch’,
‘x-label’: ‘GoodWatch’,
‘Content-Type’: ‘application/octet-stream’
body: <Buffer a3 69 70 72 6f 74 65 63 74 65 64 a2 63 76 65 72 62 76 31 63 61 6c 67 64 6e 6f 6e 65 69 73 69 67 6e 61 74 75 72 65 62 33 30 67 70 61 79 6c 6f 61 64 a5 … 122 more bytes>,
encoding: ‘binary’,
uri: ‘https://ingestion.edgeimpulse.com/api/training/data’,
method: ‘POST’,
callback: [Function: RP$callback],
transform: undefined,
simple: true,
resolveWithFullResponse: false,
transform2xxOnly: false
response: <ref 1> IncomingMessage {
_events: {
close: [Array],
error: [Function (anonymous)],
data: [Function (anonymous)],
end: [Array],
readable: undefined
_readableState: ReadableState {
highWaterMark: 16384,
buffer: [],
bufferIndex: 0,
length: 0,
pipes: [],
awaitDrainWriters: null,
[Symbol(kState)]: 200804220,
[Symbol(kDecoderValue)]: [StringDecoder],
[Symbol(kEncodingValue)]: ‘latin1’
_maxListeners: undefined,
socket: null,
httpVersionMajor: 1,
httpVersionMinor: 1,
httpVersion: ‘1.1’,
complete: true,
rawHeaders: [
‘Date’,
‘Sun, 01 Sep 2024 20:31:43 GMT’,
‘Content-Type’,
‘text/plain’,
‘Transfer-Encoding’,
‘chunked’,
‘Connection’,
‘keep-alive’,
‘Access-Control-Allow-Origin’,
‘Content-Security-Policy’,
“default-src ‘none’; frame-ancestors ‘none’; form-action ‘none’;”,
‘X-Content-Type-Options’,
‘nosniff’,
‘X-Frame-Options’,
‘DENY’,
‘X-XSS-Protection’,
‘1; mode=block’,
‘Referrer-Policy’,
‘strict-origin’,
‘Cache-Control’,
‘s-maxage=0,public,no-cache,no-store,must-revalidate’,
‘Strict-Transport-Security’,
‘max-age=63072000’
rawTrailers: [],
joinDuplicateHeaders: undefined,
aborted: false,
upgrade: false,
url: ‘’,
method: null,
statusCode: 400,
statusMessage: ‘Bad Request’,
client: TLSSocket {
_tlsOptions: [Object],
_secureEstablished: true,
_securePending: false,
_newSessionPending: false,
_controlReleased: true,
secureConnecting: false,
_SNICallback: null,
servername: ‘ingestion.edgeimpulse.com’,
alpnProtocol: false,
authorized: true,
authorizationError: null,
encrypted: true,
_events: [Object: null prototype],
_eventsCount: 9,
connecting: false,
_hadError: false,
_parent: null,
_host: ‘ingestion.edgeimpulse.com’,
_closeAfterHandlingError: false,
_readableState: [ReadableState],
_writableState: [WritableState],
allowHalfOpen: false,
_sockname: null,
_pendingData: null,
_pendingEncoding: ‘’,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
_rejectUnauthorized: true,
timeout: 5000,
parser: null,
_httpMessage: null,
autoSelectFamilyAttemptedAddresses: [Array],
[Symbol(alpncallback)]: null,
[Symbol(res)]: [TLSWrap],
[Symbol(verified)]: true,
[Symbol(pendingSession)]: null,
[Symbol(async_id_symbol)]: -1,
[Symbol(kHandle)]: [TLSWrap],
[Symbol(lastWriteQueueSize)]: 0,
[Symbol(timeout)]: Timeout {
_idleTimeout: 5000,
_idlePrev: [TimersList],
_idleNext: [TimersList],
_idleStart: 233999,
_onTimeout: [Function: bound ],
_timerArgs: undefined,
_repeat: null,
_destroyed: false,
[Symbol(refed)]: false,
[Symbol(kHasPrimitive)]: false,
[Symbol(asyncId)]: 1949,
[Symbol(triggerId)]: 1946
[Symbol(kBuffer)]: null,
[Symbol(kBufferCb)]: null,
[Symbol(kBufferGen)]: null,
[Symbol(shapeMode)]: true,
[Symbol(kCapture)]: false,
[Symbol(kSetNoDelay)]: false,
[Symbol(kSetKeepAlive)]: true,
[Symbol(kSetKeepAliveInitialDelay)]: 1,
[Symbol(kBytesRead)]: 0,
[Symbol(kBytesWritten)]: 0,
[Symbol(connect-options)]: [Object]
_consuming: true,
_dumped: false,
req: ClientRequest {
_eventsCount: 5,
outputData: [],
outputSize: 0,
writable: true,
destroyed: true,
_last: false,
chunkedEncoding: false,
shouldKeepAlive: true,
maxRequestsOnConnectionReached: false,
_defaultKeepAlive: true,
useChunkedEncodingByDefault: true,
sendDate: false,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
strictContentLength: false,
_contentLength: 172,
_hasBody: true,
_trailer: ‘’,
finished: true,
_headerSent: true,
_closed: true,
_header: ‘POST /api/training/data HTTP/1.1\r\n’ +
‘x-api-key: ei_cdd32720e0ce0c2db0cad1808ebffed94fd9b84d09087c9a4a67b7f91dfd2f45\r\n’ +
‘x-file-name: GoodWatch\r\n’ +
‘x-label: GoodWatch\r\n’ +
‘Content-Type: application/octet-stream\r\n’ +
‘host: ingestion.edgeimpulse.com\r\n’ +
‘content-length: 172\r\n’ +
‘Connection: keep-alive\r\n’ +
‘\r\n’,
_keepAliveTimeout: 0,
_onPendingData: [Function: nop],
agent: [Agent],
socketPath: undefined,
method: ‘POST’,
maxHeaderSize: undefined,
insecureHTTPParser: undefined,
_ended: true,
res: [Circular *1],
aborted: false,
timeoutCb: null,
upgradeOrConnect: false,
parser: null,
maxHeadersCount: null,
reusedSocket: false,
protocol: ‘https:’,
[Symbol(shapeMode)]: false,
[Symbol(kNeedDrain)]: false,
[Symbol(corked)]: 0,
[Symbol(kChunkedBuffer)]: [],
[Symbol(kChunkedLength)]: 0,
[Symbol(kSocket)]: [TLSSocket],
[Symbol(kOutHeaders)]: [Object: null prototype],
[Symbol(errored)]: null,
[Symbol(kHighWaterMark)]: 16384,
[Symbol(kRejectNonStandardBodyWrites)]: false,
[Symbol(kUniqueHeaders)]: null
_eventsCount: 4,
request: Request {
_eventsCount: 5,
headers: [Object],
encoding: ‘binary’,
uri: [Url],
method: ‘POST’,
readable: true,
writable: true,
explicitMethod: true,
_qs: [Querystring],
_auth: [Auth],
_oauth: [OAuth],
_multipart: [Multipart],
_redirect: [Redirect],
_tunnel: [Tunnel],
_rp_resolve: [Function (anonymous)],
_rp_reject: [Function (anonymous)],
_rp_promise: [Promise [Object]],
_rp_callbackOrig: undefined,
callback: [Function (anonymous)],
_rp_options: [Object],
setHeader: [Function (anonymous)],
hasHeader: [Function (anonymous)],
getHeader: [Function (anonymous)],
removeHeader: [Function (anonymous)],
localAddress: undefined,
pool: {},
dests: [],
__isRequestRequest: true,
_callback: [Function: RP$callback],
proxy: null,
tunnel: true,
setHost: true,
originalCookieHeader: undefined,
_disableCookies: true,
_jar: undefined,
port: 443,
httpModule: [Object],
agentClass: [Function: Agent],
agent: [Agent],
_started: true,
href: ‘https://ingestion.edgeimpulse.com/api/training/data’,
req: [ClientRequest],
ntick: true,
response: [Circular *1],
originalHost: ‘ingestion.edgeimpulse.com’,
originalHostHeaderName: ‘host’,
responseContent: [Circular 1],
_destdata: true,
_ended: true,
_callbackCalled: true,
toJSON: [Function: responseToJSON],
caseless: Caseless { dict: [Object] },
body: ‘Payload is missing, or payload length is 0’,
[Symbol(kHeaders)]: {
date: ‘Sun, 01 Sep 2024 20:31:43 GMT’,
‘content-type’: ‘text/plain’,
‘transfer-encoding’: ‘chunked’,
connection: ‘keep-alive’,
‘access-control-allow-origin’: '
‘content-security-policy’: “default-src ‘none’; frame-ancestors ‘none’; form-action ‘none’;”,
‘x-content-type-options’: ‘nosniff’,
‘x-frame-options’: ‘DENY’,
‘x-xss-protection’: ‘1; mode=block’,
‘referrer-policy’: ‘strict-origin’,
‘cache-control’: ‘s-maxage=0,public,no-cache,no-store,must-revalidate’,
‘strict-transport-security’: ‘max-age=63072000’
[Symbol(kHeadersCount)]: 24,
[Symbol(kTrailers)]: null,
[Symbol(kTrailersCount)]: 0
Still no feedback - is something wrong with my post?
The error is really silly, when trying to check-out the microphone sampling:
Screenshot from 2024-09-08 22-24-04
Hi @Christian42
Welcome to the forum!
You can try to set the sample length for the microphone,
edge-impulse-daemon –sample-length 1000 --sensor Microphone
Hi @Eoin,
thanks a lot for the feedback - sorry for my late reply.
Running with: edge-impulse-daemon --sample-length 1000 --sensor Microphone --verbose it seems the device is sending its internal parameter to the server. If you check below it shows “Sensors, Max Sample length 0s”.
Maybe that is a wrong setting in the firmware?
===== Device info =====
Type:       HIMAX_WE2
AT Version: 1.8.0
Data Transfer Baudrate: 921
[Rx ] 600
===== Sensors ======
Name: Microphone, Max sample length: 0 s, Frequencies: [16000Hz]
===== Snapshot ======
Has snap
[Rx ] shot:         1
Supports stream:      1
Color depth:          RGB
Resolutions:          [ 640x480 ]
===== Inference ======
[Rx ]
Sensor:           3
Model type:       constrained_object_detection
===== WIFI =====
SSID:
Password:
Security:
[Rx ]   0
Connected: 0
Present:   0
===== Sampling parameters =====
Label:     test
Interval:  0.00000 ms.
Length:    0 ms.
H
===== Remote management =====
URL:
[Rx ]       ws://remote-mgmt.edgeimpulse.com
Connected:  0
Last error:
@Eoin
Could you check?
With this defect the microphone of the V2 is not use-able :frowning:
Hi @Christian42
That is really strange, there should be a way to override that 0s length Let me try find out…
@mateusz can you help here?
@Christian42
You can try modifying the firmware, you may have different hardware in the device not entirely sure why or how to check that but it deos happen. One thing to try is maybe increasing the sample length to see if its able to catch anything… -
#define INGESTION_SAMPLE_BLOCKS_NUM 16 // Double the blocks for longer sample length
Recompile and flash,
Let me know how you get on…
Hi @Christian42
Sorry for the late response, but did you resolve the issue? I will try to reproduce the error on our side and will come back with update.
BR,
Matt
Was this issue ever resolved? I have run into the same issue. Using Mac OS 15.2 I can connect my Grove device via the daemon, the studio dashboard shows my device is connected to data acquisition, and the camera seems to work. However, attempts to Start Sampling from the Grove device microphone yield the same error message: Failed to start sampling - sample length is too long, maximum allowed 0 ms.
Same issue here. Any news.
I have the same issue with macOS 15.6. Any update on a (re)solution?
I have the same issue with Win10 too. Has anyone been able to use the onboard microphone or an external microphone?
Hi @Gerd @ta1mua
I’m able to reproduce the issue. Working on the fix right now.
Matt
