Hello Louis,
Thank you for your testing and your support. It looks good/works on your snapshot.
It is a good idea to test it on a original image. I did it but No objects found.
(Small remark: The PC version worked with image also. So the algorithm is OK.)
I also use the quantized model.
I suspect there is an important difference in the generated code/ (lib) between ESP-EYE and ESPCAM AI Thinker.
Is the only difference in the GPIO assignment and in the HW description or is there in the algorithm also?
In my case the #define CAMERA_MODEL_ESP_EYE is active but in your case the CAMERA_MODEL_AI_THINKER.
What is very strange that I do not have this issue when I use gray scale images.
But I can not use gray scale images when the only differences are in the colors.
I only use your Edge Impulse lib and the template example (esp32_camera.ino).
Is it not possible that there exists difference in the algorithm in the lib in the 2 cases?
(Maybe one define is missing for ESP-EYE somewhere. I am just thinking about.)
- ESP-EYE+RGB
- ESPCAM AI Thinker+RGB
Best regards,
Lehel
