I trained an Edge Impulse model and have tried to deploy it to my OpenMV M7 camera. I am trying to use the recommended firmware method but I have run into an issue. When I go to upload the firmware for the M7 camera that I downloaded, I get the following error
No matching interface for the selected file name!
VID: 14277, PID: 37379
I have run lsusb on my machine and got the following output in case it may help
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 5986:211b Bison Electronics Inc. HD Webcam
Bus 001 Device 004: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 001 Device 022: ID 37c5:1203 OpenMV OpenMV Virtual Comm Port in FS Mode
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
The OpenMV IDE when trying to load the firmware
Summary:
An error appears right after clicking the run button
Steps to Reproduce:
- Download the OpenMV firmware deployment build and unzip the file
- Run OpenMV and connect the OpenMV M7 Camera to my computer
- Go to Tools > Run Bootloader (Load Firmware)
- Select the M7 firmware bin file from the extracted zip folder
- Select “Erase internal filesystem”
- Click run
Expected Results:
The firmware to start installing and work successfully
Actual Results:
An immediate error as described above
- [x] Always
- [ ] Sometimes
- [ ] Rarely
- Platform: OpenMV M7
- Build Environment Details: OpenMV IDE
- OS Version: Ubuntu 25.04 and Windows 11
Edge Impulse Version (Firmware): [e.g., 1.2.3]
To find out Edge Impulse Version: - if you have pre-compiled firmware: run edge-impulse-run-impulse --raw and type AT+INFO. Look for Edge Impulse version in the output.
